The main water feed from the street to the basement is in PVC. The entire water system in the condo is all copper. Should there be a bond attached to the water system to the electrical ground ? Should the hot and cold copper water pipes at the gas fired water heater be bonded together ? , Also should the incoming gas black iron pipe be bonded to the copper water and or to the electrical ground? The electrical service (100 amp) with the ground on a couple of rods outside.
Thanks for your input
Petro
Petro
