I have had to do repair on my inground swimming pool copin. Have removed about 12" of the cement deck around the pool and installed new coping. They are putting rebar pins for the new concrete, should each pin be bonded tho the pool? If so can I use steel wire and bonded to the steel wall surrounding the pool or should I use copper wire?
