eager2learn
- Mennifee,Ca
I have an inspection in a couple of days and this is the situation - I've added a ground rod to a new meter main service that I recently insatlled, bonded the rod to the propane(gas), aswell as the cold water, which in turn terminates at the new service in the panel - a continuos run of course - the bonding lugs are located inside the wall for the cold water hook-up, and the gas bonding lug is located outside the wall - My question is, does the lug inside the wall, which bonds the cold water system need to be accessible? - I have added a two gang extension ring to the wall where the lug is, just in case, so that when they stucco, it can still be reached - Where in the code can I find the proper installation requirements?
