Re: bonding
jes,
The cold water pipe is already bonded if the house was wired to code. (repair if necessary under separate contract)The motor must be bonded through the GFCI supply disconnect source if the motor disconnect box has a GFCI (which it should), then the feeder running to a controller circuit enclosure that shuts down the motor due to pressure loss, heat element failure, temp limits, etc., must be bonded to the continued motor hookup.
The hookup must have an EGC grounding connection bonded back to the box. A separate ground from the isolated water system metal pipe to the motor may cause fault tripping to the GFCI.
rbj, Seattle
[ November 11, 2004, 04:40 AM: Message edited by: gndrod ]
