Bootleg ground from neutral
Srv52761
lowa
Energy Manager
Someone in a home improvement forum posted this picture and implied it was NEC approved in 2018 (probably meant 2017).
Maybe in conjunction with a gfci outlet?
Don’t remember ever seeing this before, nor read about it, either here or in any readings of the NEC. Have I missed this?
The only reason to do this would be to trick a testing device such as a Woodhead. It is considered wrong illegall and imoral. (Did I make it clear)
No. In fact, when you use a GFCI in conjunction with ungrounded grounding receptacles, you are not supposed to connect any EGCs to any terminal or each other. Clip them off at the sheath.
This avoids a malfunctioning (line-to-housing fault) load from energizing another load.
Have I missed this?
It's normally seen in old work. Its only purpose is to fool inspectors who rely on plug-in testers.
I have a plug in tester that detects that. It must measure the resistance between the neutral and ground, and if it is too low, it flags it as a bootleg.
If you wire it like this it will make sure the breaker keeps it safe, the breaker on this circuit would not even stay on imagine that?
Wouldn’t be real good for inspections, it has to boot up every time you plug it in. I use it to check for high resistance ground's and other anomalies when troubleshooting.
