electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
Well I did it, I bought one. The primary impetus was I was doing a roof mounted PV system, and although the attachments I was using do not specifically require hitting a rafter, missing requires more screws which are more penetrations, and is just all around less ideal. Also for some time I have wanted a wall scanner that can find studs thru plaster and lath because I like using side screw boxes instead of old work boxes. IT worked flawlessly and was super accurate. Highly recommend. I did find that, at least for this application, use the signal graph mode. The screen shows a graph of the reflectivity (or whatever) and the top of the curve is the center.
Maybe I should have posted this in the PV forum, but what do you guys use to find rafters/trusses? Or dont you?
