We have specified a 3P/4W service on a spec. industrial warehouse building that will ultimately have multiple, utility, metered tenants (Via separate CT meters). There will also be a 3P/3W service feeding an electric fire pump. I submitted two separate load applications since the two initial services would be metered separately (house loads & fire pump), and I just assumed the POCO would feed both from the same pad mount transformer since it is in close proximity. The POCO engineer is telling me they cannot feed 3W and 4W services from the same pad mount transformer, but he cannot tell me the reason why. I'm trying to understand in what way this is (or could be) a problem for the POCO, ground fault path, etc, but I am coming up short.
I may just have to pull a reduced neutral and land it on the Pump controller ground bar to satisfy him...seems like a waste. Can someone please help educate me if this is indeed a problem?
