hcecabigdog
I did an inspection a few weeks ago on a pool. It was to check the grid for the deck around an in ground pool. The #8 grid was made up for the concrete deck but only went about 2/3 around the pool. On the deep end of the pool were several boulders setting right on the edge of the pool. Several were stacked up to form a wall. A closer looked revealed that the boulders were setting on concrete. My thought was that these boulders are going to be climbed on from the water of the pool and can easily be touched while in the water. I red tagged it stating that the bonding grid should be installed under the boulders, they are certainly within 3? of the edge of the pool. I feel the boulders are every bit as conductive as dirt. My boss says that the code only says that it should be under walking surfaces, and that nobody should be climbing on the rocks. Any other thoughts?
Thanks in advance.
Thanks in advance.
