BOUNDING AND GROUNDING AN OFF GRID PV SOLAR SYSTEM
norwaysledge
New User
Arizona
Welder
Hello I am completely new to this forum and I have a couple questions regarding setting up Earth Ground, ECG and Bonding of a 100% off grid solar power system.
First to note- there are no inspections being done on this setup and my objectives are:
1. SAFETY
2. protection of equipment as best as possible.
Here are my questions:
How do you treat the grounding of the solar panels? I went down this rabbit hole and ended up more confused than when I first started. I watched one of Mr. Holt's seminars on grounding and bonding and from what I gathered it is not a good idea to earth ground at the panels as well as ground at the service panel.... is this correct or was I misinterpreting this. Do you run EGC from the panels to the earth ground at the service panel?? completely confused on this now.... should I run a DC Ground Fault Interrupter from the PV to the combiner box? LOL I am not sure of anything with this anymore
Next, I would be running an ALL IN ONE Inverter/charge controller (EG4 6500) In the manual this is all it states on grounding: "This inverter/charger should be connected to a permanent grounded wiring system" "the grounding system must meet the requirements of the Authority Having Jurisdiction requirements in your area"
So would I run the grounding wire (along with the AC out wires) to the service panel and then bond the neutral to the ground at that point like a typical grid tie and then ground to earth from the service panel?
Also with the battery bank and the inverter- DO YOU or Should you run the EGC from the negative terminal on the battery and the chasis of the inverter to the service panel ground??
So to summarize, I am not dealing with Code Compliance so I want this done in a way that is practical and safe and from what I was watching/reading over the course of the last couple of months there seems to be a LOT of confusion with how to properly ground these types of systems. The Panels is where I seem to get the most conflicting information.
Also I should note that the Panels will be a ground mount system that is approximately 30 ft from the inverter/battery bank and the rest of the setup will be housed in a small utility room.
Kind regards and thank you for your help.
p.s.- go easy on me, I am obviously not an electrician and I DID run this past 2 different electricians and got conflicting information which is what led me down this rabbit hole in the first place....it is slightly concerning when 2 well qualified electricians have a couple different takes on the grounding.......
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
This NEC® Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Knowledge and the practical application of the National Electrical Code is an essential part of all electrical installations. If it's important for you to understand the National Electrical Code, then look no further.
To better help us serve you, please be sure to update your account details with your occupation field and location if you have not done so already. You can access your account details by clicking on your account name at the top right of the page when on the forums.
