Brian Baker
- Basye VA
If you run size 10 wire on a 20 amp recepticle circuit from the main panel to avoid voltage drop on a long run and go in the first box with 10 and leave with 10 but pigtail to the recepticle device with 12 wire is the device value 4.5 or 5 when calculating box fill since only12 is connected to device?This is a theoretical question but would apply to other senarios where the wire may be larger like 8 or 6.
