Box fill requirements NEC vs CEC
Good morning all.
Question for Canadian electricians: Are the box fill requirements in the CEC different than in the NEC to the extent that a 2-1/2 deep metal gem box stamped with "12.0 cu in" inside the box is allowed to have (3) #12-2 MC cables enter the box and also, upon trim, will have a device (receptacle) also installed within the box? A client who has relocated from Toronto, CA to here in SW Florida claims that they allow this configuration. ? Of course the electrical inspection failed miserably and all the 1-gang gem boxes had to be changed out. To which the GC stated "well, I guess some things we can do in Canada we cannot do here". Can I get some clarification on this from Canadian electricians?
Thanks in advance.
I'm no Canadian, but I have studied a bit of the CEC, and the way I understand it, you can get more wires in less volume, but wire nuts count as well. Every pair of wires connected together counts off 1 conductor. All grounds count individually. And the device counts as two.
I looked it up, and each #12 consumes about 1.75 in³, so three 12-2 MC cables would be 9 conductors and a device is 17.75 in³, then at least 3 pairs of wires have to be connected, so that is another 5.25 in³, bring the total up to 24.5 in³.
I could be off a bit, but I don't believe the CEC allows three 12-2s and a device in a 12 in³ box.
Obviously the box fill does not meet NEC or CEC requirements. I can't imagine trying to splice (3) 12/2 cables in such a small box let alone try and get a device into it.
For me (3) 12/2 MC cables would be getting a 4SQ deep with single gang ring. Standard 4SQ meets NEC but minimal additional cost but makes life much easier.
Thanks for your opinion. Take care.
No Canadian code does not allow 3 x 12/2’s in that box.
As you can see on table 23 that was posted, it shows a max of 7 x 12 awg conductors for a 3x2x2 1/2 device box with a 12.5 volume.
Canadian code counts all insulated conductors. (12-3034)
A bare ground would not be counted but an insulated one would be. A device counts as 2 conductors and every two wirenuts count as one conductor.
With an MC cable, the insulated ground would have to be counted, but even if you used Canadian AC90 with a bare ground, 3 x 12’s would not pass. You got 6 insulated conductors, 2 for the device and another one for two wirenuts. That would equal 9 conductors. Table 23 says 7 max.
