nakulak said:
800.110 - if wires are installed using a chapter 3 method then they will meet the requirements of the chapter 3 method (paraphrased)
I get nailed for paraphrasing all the time here :roll: !
Look in 800.110...
Exception: Conduit fill restrictions shall not apply.
nakulak said:
- this says to me that you need to calculate the conduit fill just like you normally would for any other application in chapter 9 table- after adding the nominal wire circ mils you can look up the com cables dimensions from the manufacturers cut sheets. -we regularly use this method in fire/gas detection systems for conduit fill.
State the article and I will go read it
I couldn't find your CMP wire to determine that in 310.13 or in the 500's.
nakulak said:
-the box fill is the real question. hmmm, I'll be interested in seeing the answer to that one. if the raceway is, say 40%, I don't see where any size box would be an issue (given that reason for the fill is heat dissipation), but the question deserves an exact answer.
(a lot of cmp wire is only rated 300v - this installation will have to use the 600v rated variety, correct ?)
The Code says 300.2
Limitations
(A) Voltage. Wiring methods specified in Chapter 3 shall be used for 600 volts, nominal, or less where not specifically limited in some section of chapter 3.
That kind kills appling load or Box calc's doesn't it ?
300.3 (C)(1)
Conductors of Different Systems.
(1) 600 Volts, Nominal, of Less. conductors of circuits rated 600 volts, nominal, of less ac circuits and dc circuits shall be permitted to occupy the same equipment wirring enclosures, cable, or raceway. All conductors shall have an insulation rating equal to at least the maximum circuit voltage applied to any conductor within the enclosure, cable, or raceway.
Buy a pinching measuring device, a digitial read out is good.
As I said it not allowed, teach me something otherwise, I go with the seperation requirement in a device box,
but not that I practice that
