mstrlucky74
- NJ
I have (4) 6? conduits entering one side and exiting on theopposite wall. (2) spare and (2) w/ 3#500 & 1#4/0 each. What size box wouldI need?
Thanks.
Thanks.
Thanks.
There is no exception that I am aware of that would permit that. If you are talking about the last paragraph in 314.28(A)(2), that is used to find the required box size where a cable wiring method is used. You can't use that if a raceway has been installed.Code section 314 Even without the code book this one is easy. opposite wall is 8 times the diameter of the largest conduit, BUT there is an exception that allows you to use the nominal conduit size that the conductors can fit in if you use oversized conduit. So for current wires I believe that 3 #500 and a 4/0 can fit in a 3" conduit so 24 inch can.
Yes you do. How to do it is explained in 314.28.Don't you need to figure spacing for other (3) 6" conduits on top of the 8x6?
Sent from my iPad using Tapatalk
A 4 11/16 with 1 1/4" eccentric knockouts in it. In no case does that box comply with 314.28 (A) 1 or 2. The rule I was thinking of that I may have dreamed was one that would allow this. Please enlighten me.
You can use that box with an 1.25" raceway and conductors #6 and smaller.
Per which code section that I can't find?
