Shockedby277v
- Michigan
Boxes roughed in stud walls with wire in them..... do they require a cover to protect the wire from rotozips or whatever??? Per code??
If it's required, I sure missed it on a ton of inspections. I've seen various methods used for protection, none of which seemed adequate from a dedicated roto-zip operator.
My guess would be an energized circuit would do the trickMost of you won't see this as funny but my Dad broke the drywall mudders of cleaning their trowels off on his boxes. Any guesses as to how?)
Yeah you got that right. I push them in as much as I can. I was told by someone once that they are supposed to run that outside the box. It's a lot of fun when they not only cut the wire but blast through the threads also.
My guess would be an energized circuit would do the trick![]()
