boyo
- Cheboygan, Michigan. USA
Hi to all,
First time on here. Keep up the great work. I know you can help me. I now work in Mackinaw City Michigan as a part time electrical do everything. I fix (try to) everything.
My boss has 28 Hotels and almost all have had 12 volt poolside chair lifts put in. my question is: the guys are running the ground wire from the chair lift to the breaker panel ground. I don't agree with this as you may get a stray voltage come back on that ground wire.
I think they should be bonding to the pool ground and may be a ground rod near the chair lift, just in case the ground wire breaks as it is about 100 feet long on some pools. They like to run them where they dig for plants.
Chiar lifts are 12 volt DC battery that have to be recharged in a different room
