Re: Branch circuit calculation for rack mount IT equipment
Kalanjeta,
1.) Raid 5
Block Interleaved Distributed Parity: Provides data striping at the byte level and also stripe error correction information. This results in excellent performance and good fault tolerance. Level 5 is one of the most popular implementations of RAID.
That is a real fancy definition isn't it
Now, what that means to me is this. In a raid 5 setup I have 6 hard drives, 5 active and one on-line spare. The system sees the 5 drives as one big drive and my data is spread out (striped) on all five drives as 1's and 0's. The good things about this setup is if I have one drive go bad, the system is smart enough to figure out which 1's and 0's is missing and start rebuilding them to the on-line spare drive.
2.)Mirrored setup:
A technique in which data is written to two duplicate disks simultaneously. This way if one of the disk drives fails, the system can instantly switch to the other disk without any loss of data or service. Disk mirroring is used commonly in on-line database systems where it's critical that the data be accessible at all times.
Another fancy definition. We use 3 disk for this setup. Two as our online disk and one for a spare. Again if I lose one active drive my spare kicks in and I am still online. Not as reliable as raid 5. The power consumption will be less though because of the less number of drives.
2.) 42U rack:
This mean nothing more then the height of the rack itself.
Hp Racks
3.) Server blades:
These guys are nothing more then a server in a smaller package. In a rack space of 20U I can get 10 DL380 servers (2U of space for each DL380). In that same 20U space I can get 3 server blade cages and in each cage I can get 8 server blades, which means 24 servers. For better information check out HP's web site.
4.) S.A.N. (Storage Area Network)
We have a large rack out on the floor that does nothing but act as a data storage area. This setup is like this:
12 cages in the rack
each cage can have 14 drives, I think we have 10 146.8 GB drives per cage right now. So if you do the math that is 17.616 Tera bytes of storage space, that is a lot of damn space.
5.)The setup inside of our racks:
Check out this pdf.
Rack setup
So for a standard rack I would install two 208V 30A circuits. One circuit coming from UPS-1, and one circuit coming from UPS-2.
For a Blade rack I would install 4 208V 30A 3-phase circuits. "Scotty, I need more power"
Well, I sure hope all this means something to you Kalanjeya, but my opinion I would rather be in your shoes, a "EE"
Thanks,
Kevin
