branch circuit openings ??
sundowner
West Wisconsin
Could anyone help me find where it says how many openings are allowed on a single 20 amp circuit... for example six can lights with six outlet receptacles in the living room, a switch on each wall... (14 openings) would you state where it was found also. thanks
Re: branch circuit openings ??
Dwelling Unit?
How many do ya got?
You can put as many outlets as you want on general purpose Branch circuits in a dwelling unit.
As long as the homeowner dont know it was you who did the work when the breakers start tripping. :mad:
6 cans and 6 receptacles in a living room trip a breaker :confused: On a 20 amp circuit........It`s fine !!!!!!!! what will there be?A lamp maybe.TV,dvd player,surround sound.Maybe 10 amps at the highest......Sundowner with #12 use 12/13 openings as a basis to wire by,oh and switches don`t count.IWIRE is correct there is no max.But 1 general purpose circuit per 500 sq. ft. Is another way to go by.Don`t forget those recessed cans they add up.Compensate for them.I have used this to go by since the point system went bye-bye.
