kevinware
- Louisville, KY
Hey everyone,
I'm sure some of you have seen my post entitled "more about voltage drop" posted in the calculation section. Well now I need some NEC input. My first post stated my concern about voltage drop of two 20 amp 120 volt circuits 200 feet away from the panel that I needed to come out of. Well to make a long story short, I decided with a little help from everyone's input here, to run my 20 amp circuits using # 10 THHN and use industrial grade 20 amp rated receptacles Levington part # 5362-I. According to manufactures specifications I can use wire sizes # 14 - # 10 stab through the back of the receptacle. So this is what I have. I have two 20 amp branch circuits with 20 amp OCPD using # 10 THHN wire terminated on industrial grade 20 amp receptacles. I tell my lead man that this is the way I was going to install these circuits and he tells me that I am in violation of the NEC because my receptacles are only rated for 20 amps and my # 10 is rated for 30 amps. To my understanding of the NEC the OCPD determines the rating of the branch circuit and not the wire size. So to my understanding as long as I use a 20 amp breaker it really doesn't matter what size wire I use, I still only have a 20 amp circuit and my industrial rated receptacles are rated 20 amp 125 volts but are just able to except a wire size up to a # 10. Am I wrong in my thinking?, please correct me... One more thing, there are no motor loads on these circuits. If my lead man is right can you give me the code reference?
Thanks,
Kevin
Thanks,
Kevin
