Crown Electrical
BBKing
- Michigan
- Master Electrician/designer
I understand the EGC continuity is required to be independent of the receptacle (in this case 120v yoke). Is this also true for the Hot (black) and Neutral (white)?
Seems like a good practice however I can not locate (in Article 210) that this is required.
If this is required, are the whips counted as conductors in box fill calculations?
Thanks.
Thanks.
