As many as the panel is listed for. As long as the load does not calculate over 60 amps you could have 100 circuits- of course you wont find a panel like that.What is the allowable number of branch circuits in 60 Amp sub panel.
Don't jump to conclusions. I have not seen or heard of a 100 circuit panel, but I know there are 84 circuit panels available, the mains are likely not 60 amp but nothing is to stop you from supplying it with a 60 amp feeder if the load is 60 amps or less.
I said there are no panels with a 100 circuits. My point was simply there is no limit other than the panel itself which I clearly stated-- I thought.
