mstrlucky74
- NJ
So a pnel feeding thee circuit is about 100' away. No shared neutrals allowed. So essentially I guess you need separate MC cable for each circuit or multiple neutral MC. Blue lines represent the MC cable and the black squares are the home run boxes. Questions.
1. I guess only one HR box is needed. COuld just extend the branch a little further?
2. Would you use a multiple neutral MC for any of the circuits? Why and which one?
3. The (4) receptacles on ckt #23. I know this may be a dumb question but I've been told many times to just figure from each receptacle up a 'X' footage to a box and you'll come up with overall correct footage. But in this case( and many others) in my mind this is how it would actually be wires in the field. Drop cable down to receptacle rto left of room name then run horizontal in wall to other receptacle right above room name then rise up and across room to receptacle to the right of the door in the same room and then back up from that receptacle and down to the other receptacle to the right of the door in the other room. THis would take care of all the ckt #23 receptacles. Does that make sense?
