Hello gents! I’m installing a generator inlet and transfer switch for a client and have a question about wether or not to break the neutral.
The clients existing home setup includes a exterior utility disconnect panel and two sub panels (branch panels) located in his garage. The neutral & ground for the utility is bonded inside the exterior disconnect panel (first point of disconnect). The neutral then feeds to the neutral buss on the sub panels (inside garage) and ground is sent to earth (via rod) and to sub panels ground buss.
I will be installing a manual transfer switch (with inlet box) between his utility disconnect and branch/sub panels. His generator is bonded and will be installing ground rod (for earth ground). Here’s my question: With the generator being bonded, should I break the neutral (3 pole) at the transfer switch or not (2 pole)? I’ve heard arguments for both and just want to do what’s best. Thanks!
