CelectricB
- Texas Panhandle
- MEP Designer
How long has the retention requirement been around?You are talking about back feeding a breaker. Most panels have a designated spot at the top for a back feed breaker. remember these breakers must have a hold down kit so that determines where it will be in the panel.
I don't knowHow long has the retention requirement been around?
Thanks for the quick response, Dennis!You are talking about back feeding a breaker. Most panels have a designated spot at the top for a back feed breaker. remember these breakers must have a hold down kit so that determines where it will be in the panel.
Not on all panels from what I remember. I think GE has a spot near the top for their hold down kit.The back-fed main CB can go anywhere in the panel.
Which is easy to do with a panel board, because the breakers bolt in, but some load centers only have a hole tapped for the hold down kit in certain spots, but yes, it can be anywhere other than that.The back-fed main CB can go anywhere in the panel.
Sorry I meant code wise there is no limitation for a panel like the one in the OP.Not on all panels from what I remember. I think GE has a spot near the top for their hold down kit.
They may have changed that because of the solar breakers which are required to be at the bottom.
I assumed much earlier, but not seeing in '75 NEC (384 is panelboards that year)first required in the early to mid 1990's.
I know this is an old thread, but I wanted to let you know, you can special-order the smaller rated BR breakers with a hole in them for the hold down screw. I think BR260 and above come with it anyway, but for the smaller sizes such as a 30 or 40 amp, you just add a B on the end of the part number. For your 30 amp example, you would need a BR230B instead of a BR230.Problem is the smaller breakers do not have the hole in them so you can't put the hold down on it
I have been in the trade since 78, so then for sure. If you really needed to know go to NFPA.org and search previous editions of the NECHow long has the retention requirement been around?
