breaker and conductor sizing
when breaker size of a motor load is determined by 430.52 in the NEC, does the wire size need to be changed to match the new breaker size?
Re: breaker and conductor sizing
Size conductor by 430.22 and OCPD by 430.52
As outlined in your last post the 71/2 HP motor would have a #10 conductor with a 70 amp breaker. Should this breaker not hold then this could be increased to a 90 amp breaker and still use the #10 conductor.
The purpose of the breaker is to only provide short-circuit and ground-fault protection. The conductors are protected by the motor overloads. This is one reason why the difference between overload and overcurrent needs to be fully understood.
Just my opinion but the wire size for a single motor is sized using motor table of article 430. To get the FLC and then 430.22(A) tells me to multiply the FLC from the motor tables by 125%.
EX: 10hp 3 phase 208V = 30.8 FLC
Applying 430.22 30.8 x 1.25 = 38.5 Ampacity
Looking at table 310.16
38.5 Ampacity lets round up to 40 amps (220.5(B))
and we will assume "THHN" and equipment rated at 75 degrees. 40 amps Ampacity = 8 AWG THHN
And for the OCD if you are using Inverse time breakers. 38.5 x 250% = 96.25 Amps. 240.6 tells me I can use a 100 amp breaker. Article 240.4(D) does not apply to motor circuits. Lets see what others have to say, I am just an apprentice.......
Kevin
