I'am putting the electric in a newly framed house on an Island in Maine. I plan on having the breaker box by the front door, but the power has to come to the house on the other side. According to a contractor friend in Chicago where I live you can put a disconnect on the outside of the house after the meter where the power comes in and then run a certain distance to a breaker panel located in a different location. If I understand it correctly, the jist of it is that as long as there is a disconnect that is accessable where the power comes to the house it's OK to put the breaker box in a seperate location. Do you know if the same is true in Maine? or what distance you can run after the disconnect to the breaker panel?
