Take the kVA rating of the transformer divided by the secondary voltage, which in our case is 480V to get the secondary current in amps.
If you have a three phase transformer then you need to go a step further and divide the result that you got above by a factor of 1.73. Your calculation would look something as follows:
Secondary FLA = kVA rating / .480V / 1.73
