francis.key19
- frederick, md
Hello,
We are trying to standardize control panels for all of our equipment and plant. Due to various loads on each equipment, we are looking to build panels with say 400 A main disconnect build into each panel. We would then only populate these panels depending number of contactors and load demands (meaning the ultimate load will be 300A or less). Is there any issues any one can see with this setup.?
Since these panels are remote from our MCC or switch gear room (about 120-300ft), we would add a breaker ahead of each panel sized for the actual load. This means that the remote breaker will trip before the one on the panel will (in the case of overload).
Does the code allows this?
Thanks.
Francis Key.
Thanks.
Francis Key.
