Breaker Labeling Question
NYCNeal
Chicago, IL
Installer
Greetings!
On two successive jobs instead of having the breaker diagram/identification written in the boxes on the door label, I've encountered these helpful placards inserted over the breakers. They usually fall to the floor when I open the door. One was pretty slick, printed and laminated), and the other was marker on cardboard.
It's in the spirit of article 408(A), and it's better than nothing, but I have to wonder if this is correct, and, if not, what should be done to correct it.
Thank you!
Neal
I make my own using Excel and then I print it out. I attach a clear plastic sheet holder to the door and slide it in. Can easily be updated when needed and colorized if you so choose.
