Is it ever permissible per code to load a breaker more than 80% (Assuming it is not a 100% rated breaker) in particular for motor feeders and services supplying multiple motor loads. Following overcurrent protection calculations per aritcle 430.62 and 430.63 I understand that the breaker can be sized larger than the ampacity of the conductors for motor feeders. But what about when you have so many motor loads that you run into a situation where the breaker is less than 1.25 times the connected load? Need some clarification.
