jph320
- Cinnaminson nj
- Electrician
Is there a section in the code book that says you have to use the same name breaker as the panel?
where does it actually say that un the NEC?The NEC says that if the panel manufacturer only lists their own specific brands for use in it you have to follow that instruction.
OK, that was "list" as in includes in a written list, not as in NRTL listed.where does it actually say that un the NEC?
the panel manufacturer cannot "list" anything. Only an NRTL can list them.
Look at the label on most panels and you will see a "list" of allowed breakers.
