Gtsco12
- Orange Park Fl
- Electrician
Mike while working on a job a twin 20 amp single pole breaker was used in place of a full size breaker in order to add an additional circuit . All spaces were being utilized. I was told I needed to re number the panel to identify the breaker in it's space. Example: breaker slot #4 would become #4and#6 My argument was you are not allowed by UL standard to change the number orientation of the manufacturer stamped numbering system. logic would be if you were to add a twin single pole breaker in a full breaker slot you would keep that same number in the case#4 and mark #4,a and #4,b in this way you are assured the correct circuit and not throwing the manufacturer's numbering system off . This is a safety concern . Is there anything in the NEC that refers to what I'm referring to?
