olly
- Berthoud, Colorado
- Master Electrician
I'm trying to determine a few things about a Zinsco panel change:
Is it common to have problems with arc fault breakers tripping after the upgrade? Anything is possible but is it common?
As far as bidding goes:
The panel is not labeled well so I would have to trace out every circuit. Located in the garage so
a pretty straight forward change out (no drywall) roughly 20 circuits. What would you bid this job? In Colorado where the Avg home price is $350K
Thank you
Thank you
