I've heard this several times before, but I've never seen a panel so marked. Can someone clue me in on what brands or models these might be, so I don't do something bad down the road?Originally posted by LarryFine:
Many panels have a stated current-limit per stab, often 100 or 125 amps, so you shouldn't put the largest 2-poles opposing each other, which is another reason I do it this way.
I'm sure that SQR-D and Siemens are similar. Granted I don't work with residential stuff much, but I would think that there are similar restrictions.220A double branch maximum (100/120A, 90/130A, etc.).
I have: I got a nice zap from a 50a range breaker mounted opposite a 60a electric-heat breaker, and the contacts of one pole of the range breaker welded closed.Originally posted by allenwayne:
Have never had a problem with 2poles side by side or opposing phases
