Bill Snyder
NEC expert
- Denver, Co
- Electrical Foreman
Would I be able to load a breaker to 18A if the load was not continuous? And also are lighting circuits in commercial considered continuous load?
I assume this is a 20 amp breaker you are referring to? The answer is yes, you can put up to 20 amps of non continuous load on a 20 amp breaker.Would I be able to load a breaker to 18A if the load was not continuous? And also are lighting circuits in commercial considered continuous load?
