CarlosJr
- California
- Electrician
I was called back to look at a recently completed whole house rewire project. It has a newly installed Siemens load center with 20A AFCI breakers. The customer complained of flickering lights when he ran a 120V in-wall AC unit.
Steady state, the AC unit consumes approximately 1200-1350W according to a Kill-A-Watt meter and this causes a voltage drop from 110V -> 105V on its circuit. The voltage drop seemed high to me compared to other circuits in this residence that I tested under load. Not horrific, but high. I calculated that for the ~50ft run of 12/2 @ 13A, the drop should only be about 1V on each conductor = 2V. Popping the dead front off the panel and checking with an IR camera, I did see that the loaded circuit was about 120F. The load center is indoors so ambient temp is in the low 80s. And of course all of the other AFCIs in the panel run a few degrees over ambient to power their circuitry.
Could this be an installation/equipment problem or is it normal?
