Working for a contractor who wants to put a 1/0 Al wire on a 70 amp siemens breaker. Wire is already pulled. I don't think it will happen, (can anyone confirm max wire size to breaker size for siemens) short of a special order from the factory.
The 70A breaker is the main for hundereds of sub-panels in a high end project, so if special order is only way, they can do that.
Haven't seen any of the panels, but believe it is a bolt on breaker with 125 amp bus bars. Think it would be cheaper to just install 100 amp breakers, but that is a whole different issue.
