Hi,
In the power plant the elevator controls were replaced. With the old control they never had an equipment grounding conductor run in the raceway from the load center to the elevator motor. They have ground grid in the plant and each peace of equipment is grounded to the grid. Now, with new control they connected equipment grounding conductor between an elevator control cabinet and the fused disconnect switch in the elevator room and they tripped circuit breaker in the load center (in the basement). Breaker tripped on ground fault (breaker has solid state trip unit GE). Elevator control cabinet, elevator motor and disconect switch were connected to the ground grid at both cases.
This is happening on two different elevators.
I will appreciate any ideas about what is going on here.
Thank you.
Thank you.
