JDB3
- San Antonio, Texas
Just had a call from a customer. A thunder storm was in their area and caused over half of their breakers to trip. :jawdrop:
Ever hear of this?:?
Never had it happen to me.Just had a call from a customer. A thunder storm was in their area and caused over half of their breakers to trip. :jawdrop:
Lightning will most definitely do this as the increased voltage due to a nearby strike will also cause a rise in current and can therefore trip an ocpd-sometimes it may be only one or in your case, many. Obviously your going to want to check for damage due to surge- inspect bus, and breakers, pull devices, etc. Some guys will claim you will want to meg also, whether you do this is up to you.
One things for sure about lightning-all bets are off and it does what it wants to do.
I would say it should be done as a sensible precaution against future problems. Problems that when they occur will all be the fault of whoever gave the go ahead to switch on.
