2. Use a peak capture amp clamp and capture the inrush current.
3. A 20 amp CB should be able to hold 160-2900 amps Instantaneous current.
290 or 2900 what the heck it's just a zero off.
the megger is the best problem solver IMO. most people dont understandthem and think a standard ohm meter will work but they wont find a high ohm fault
Couldn't you find a high ohm fault by removing all loads from a circuit and testing the conductors with an amp-meter?
