A
a.wayne3@verizon.net
Guest
Here is a really good one !!!!! A home built 2 years ago sat as an inverntory home for almost a year.Then the problem started.1st service call was for tripped breaker in family room,this was recieved in late afternoon to answering service.So we sent service crew there in the am.
Breaker was holding fine.A couple of weeks passed
Another call same thing again we sent service .Same thing no defect found :roll:
A couple of weeks go by same thing.So I went there to take a look sure enough the breaker was tripped.Continuity check showed all conductors clear,this was around 1 pm.I changed the breaker figuring maybe it was just a weak breaker.That eve another call breaker tripped again.I had informed service that if another call was recieved I was to be called.I got there around 5 pm and breaker was tripped and when i reset it it tripped again i opened the circuit up and checked all conductors they now showed no hot to ground continuity btw this is nm 12/3 installation for switched receptacle.By this time now I am confused,I reset breaker and it holds.I use a toner alot so i left the power on all devices pulled out of boxes and started checking.Then I found it 1/2 way between 2 receptacles the toner started to buzz loudly when i passed over the baseboard at a seam.I informed homeowner that I had to cut the drywall there.By this time she didnt care if i ripped the wall down.Builders warranty still in effect.When i cut drywall just over the base there it was a finish nail had penetrated the 12/3,I cut the nail and a section of affected wire out.The nail had gone almost completely through the hot and had grazed the neutral.So why only in the afternoon does this happen ??????????The only thing I could figure was that during the day the heat built up in the block wall and expanded the metal from both the finish nail and the nm contact made and bam tripped breaker.Service crew was there with me I had them change the affected wire and no more problems ....... By the way this area here Hillsboro county allows nm to be staples to top of 1x4 or wider pt that is nailed to the block,with out stand offs or stackers as some call them......
