bensonelectric
How many times can a breaker be turned off before it is worn out?
Short answer, he was looking to make the testing take as long as possible keeping the building closed for business.Originally posted by physis:
I don't even want to know what the fire guy was looking for![]()
means that the breaker must not only pass a given number of mechanical operations but must also pass electrical performance test which should make you very secure in applying breakers in switching applications.How many times can a breaker be turned off before it is worn out?
Nope, I do not, but I bet templdl probably knows.Originally posted by physis:
Bob, you would probably know about this, or a lot of you guys for that matter.
What is so special about HID as a load that there's a need for identification in 240.83(D)?
