jcook106
New User
- Roseburg, Oregon
T here may be a simple answer. Did you look at the nameplate and lable for the transformer? It should be UL listed as an assembly. While in OEM sales I provided numerous breakers tty O one of my major liquid cooled padmounted trsnsformer manufacturers. While working for a custom drytype transformer manufacturer we provided molded case breakers mounted in the LV ATC of our transformers. But, they must meet the requirements of our UL listings for the assembly.I have never seen an installation like this before:
It seems like such a bad idea... But, I can't find anything in Code or Standard which says you can't do it.
You have a cut sheet for what you describe? I have seen combination MV and LV units, but never where they were built into each others wiring compartments: They were always built with segregated space so neither the switchgear nor TX interfered with the each other.It’s a common arrangement throughout the world. You order a single unit and it arrives as a monoblock assembly of MV switchgear, transformer and LV switchgear. I’ve installed a few in the UK, so long as you have the groundwork in place they really speed the job up.
... but never where they were built into each others wiring compartments...
