bcl
- Garden Ridge, TX
- Electrician (Owner/ Operator)
Hey all, I've got a customer who says his power goes out often where there are a lot of new homes being built. Whenever the power goes out, multiple single pole breakers trip. I think it's the AFCI breakers, but he can't really confirm. Set up is main breaker/ service panel exterior, lighting and outlets on the interior sub panel. The interior breakers are the ones tripping. He said once that all the breakers on one side of the panel had tripped when the power came back on, other times it's just a few breakers. He's not the only one in the neighborhood who is having the same problem.
The only work I've done on the house is install a surge protector (Siemens FSPD), it was built in 2016.
I've swapped out a number of spec grade CH AFCI breakers in the same neighborhood that begin nuisance tripping after 3-4 years, but I haven't had a problem with them tripping every time the power goes out and comes on again.
Any suggestions? POCO doesn't take any responsibility, and the problem isn't going away as long as there is new construction going on in the neighborhood. The power goes out a couple times a month.
