Brownetown
- Va
- Electrican
I did a 26kw Briggs generator. For control wire I decided to pull 14awg. As I was done I was reading the Manuel it called for 18awg twisted pair. Do you think there will be any interference?
Not likely but possible and guaranteed to get the blame if it doesn't operate correctlyI did a 26kw Briggs generator. For control wire I decided to pull 14awg. As I was done I was reading the Manuel it called for 18awg twisted pair. Do you think there will be any interference?
Does Briggs allow power and control in the same raceway?Okay maybe I’ll pull it out and run twisted pair. I was trying to just keep all in one conduit and figured since both was rated for 600v. If I put 300v and 600v wire in same conduit I should
Be good considering service is only 240v correct?
It is said that, to find the easiest way to do something difficult, one should ask a lazy person.
It is said that, to find the easiest way to do something difficult, one should ask a lazy person.![]()
