ericsarratt
- Utility Contractor, HVAC Service Tech, Septic Installer & Subsurface Operator, Plumber
You can stare at the sun and get some sun spots momentarily that go away in a few moments. This isn't recommended.
If you stare at a welding arc it will damage your eyes--arc eye.
In relation to electrical work, I have read different stories about arc flash that range from nothing happen to temporary blindness (about 10 minutes) to permanent blindness, depending on the intensity of the arc.
So is arc flash just a very powerful burst of the same energy that you see in the welding arc?
