hole snipe
- NJ
I had a trouble call at a detached garage that is fed with uf cable. The customer lost his lights and everything out there. I checked the hot leg to equipment grond and read 120v. Then I checked hot to Neutral and also read 120v. But when the neutral is connected to the loads, they don't respond. I flashed the twisted neutral loads to equipment ground momentarily, and bingo! everything worked. It was obvious that There was a break in the neutral in the earth or a bad splice. I ran out of daylight and have to go back tomorrow morning. My point...why was I reading potential from my ungrounded conductor (hot leg) to the supply neutral and it doesn't work the load. A break?? That is my assumption.
