Re: Brown outs
Utility line switching and fault clearing operations caused from L-L faults via wind, L-G faults via trees, lightning over loads, etc.
For example if the fault is on your distribution feeder your lights will dim shortly, then go out for a few seconds, come back on dimly go out again, then the third time if the fault does not blow clear you get a lock out, and your power is out until the fault is cleared by the utility.
Maybe Charlie will elaborate.
[ August 04, 2004, 04:29 PM: Message edited by: dereckbc ]
