Please help me with this one. I received a call to a house on a beach that had their TV and lights acting funny. They had called the cable TV Co because of a cable problem and they said that the system was damaged and replaced. A cable splitter was found with a cable burnt at the connecter. Assuming lightning strike. I start at the panel. I have 130v on A leg and 118 on B leg. 249 across both. A toaster was turned on at the counter and the TV screen on the other wall would deform in color and eventually turn off, and the kitchen recessed lights would dim also. There is absolutely no overload as expected but a voltage drop to 90v. The TV is on a separate branch circuit. Back to the panel I go. I turn off all the breakers except for one in the basement with two pull chains and a dehumidifier in the corner. As soon as the dehumidifier calls I would read a quick voltage drop ahead of the main breaker. This problem occurred when any motor or call for current was being received. Is this a brownout? Please help.
