bubble cover
GerryR
Is there any four and a quarter inch deep bubble covers in the market ? I have a situation where the pool pump has a molded plug that measures four and a quarter from the end of plug body to the bent portion of the cord so theres no way I can close the cover I need a very deep single gang cover.Has any one else run into this situation? Thanks
Would it be possible to cut the molded cord cap off, and install an angle plug?
~Matt
buuble cover
buuble cover
Thanks guys for the reply I figured that was my alternative.Someday maybe the plugs will be manufactured for right angle for pumps since bubble covers are needed.
Maybe a deep cover combined with a recessed receptacle, such as a clock receptacle, would be deep enough.
I bought one of these at Home Depot once. They may have one there if your supplier doesn't have one.
See page H27 & H28 Model CKLSVL
http://www.thomasbetts.com/contractor/docs/reddot.pdf
http://kscdirect.com/item/THO+CKLSV...TLET+CVR%2C1.594%22+RCPT+RED+DOT+W%27PROOF%0A
bubble cover
Thanks again for your input.Today I found a deep single gang bubble cover made from intermatic part number WP1150C measures four and three quarters have it in my hands just what I needed I hope this helps someelse in this situation.Thanks
