MikeLechiara
- Orange, CA
We recently installed a buck and boost transformer for a machine shop where we needed 5A of 3 phase 480V but had a 208V system. We fed a 9kva 208v to 480v xfmr with a 3P 20A main breaker. The machine shop wanted a disconnect on the primary side of the xfmr because they don't use the machine every day. Once we connected the xfmr to a disconnect, it tripped the circuit breaker. We upsized the breaker to a 30A but it still tripped. So we then tried a motor rated switch without overload protection, but that also caused the circuit breaker to trip. Once we take the switch out of the picture, the circuit breaker holds fine. What causes the circuit breaker to trip and how can we provide a means of disconnect that won't create this problem?
